If you are experiencing low volume output from your Icon IC 41 Pro speaker/microphone, there could be a few possible causes. Here are a few things you can check:
Check the volume settings: Make sure that the volume on your speaker/microphone is set to the maximum level and that the volume on any connected devices (such as a phone or computer) is also set to the maximum level.
Check the audio source: Make sure that the audio source (such as a phone or computer) is not set to a low volume level.
Check the cables: Make sure that all cables are properly connected and that there are no loose or damaged connections.
Check the battery: Make sure that the battery of the speaker/microphone is charged or replace the batteries if necessary.
Check the speaker: Make sure that the speaker of the speaker/microphone is not damaged or blown. A damaged speaker can cause a low volume output.
Check the microphone: Make sure that the microphone is not covered or obstructed. A covered microphone can cause low volume output.
If none of these steps resolve the issue, I would recommend contacting the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or may recommend a qualified technician to repair the speaker/microphone.
It's worth noting that if the speaker/microphone is under warranty, you should contact the manufacturer to have it repaired/replaced.
In-car entertainment systems, especially the types chosen for camper vans, etc., are often capable of quite high power outputs and usually need speakers capable of being driven at those high power outputs without damage.
The trouble is, such speakers usually don't sound so good at the very low volume settings needed for evening and late night use in a campsite environment to avoid annoyance to neighbours.
It is a big problem choosing speakers that sound good at low volume and yet can withstand the higher volume needed to overcome the wind and road noise of driving. There have been many technological advances in speaker design and a hi-fi specialist will undoubtedly be able to make suitable recommendations that are resistant to damp conditions, long-lasting and with cones free enough for good reproduction at ultra low volumes but robust enough to withstand high power outputs and such drive units are likely to be fairly expensive.
For myself I would choose to use a dual speaker system with a multi-speaker system comprising several low-powered speakers strategically placed for low volume use and a fairly standard high-powered system for normal use and a selector switch.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
The most obvious solution would be to check the volume settings either by using the volume control on the side of the phone, or through the audio settings in the settings menu. If everything is already set to high then the next thing to do would be to check for water damage/physical damage. If you look through the headphone jack you should see an indicator for water damage. If there is no liquid it is white, if there is liquid it turns red. If it is red then there could be water damage affecting your speakers, otherwise if it is white check the speakers themselves. These speakers are pretty much made of paper so anything could harm them. All in all though if everything seems to be ok, but the speakers are still low take it to your carrier or the apple store. The iPhone has a 1 yr warranty but sometimes the apple store will take care of it for you even after the 1st year.
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
I have a RAZR v3 and I used the P2KTools VS to seem edit the volume. It is free and very easy to use.(DO NOT EDIT ANYTHING ELSE AS YOU CAN TOAST YOUR PHONE AND VOID WARRANTY) Just go to the sound application and load the settings from your phone on that page.Then, just click the arrow next to each volume settings just a notch or 2 to increase the volume (eg: for setting 7 to 9 volume) then set it and your good to go.
Audio amplifier IC faulty that why you get very low volume. Else check audio driving circuit to the audio power amplifier. Contact service centre. as there is no rectification process from user part
