What size inverter do I need to use for a submersible sump pump - discharge of 3800 gph at 14 ft. lift with pressure switch? Will the Husky 750 work?
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
