I have 2 of these cameras and they both work fine. I just recharged the batteries in both cameras and they now take good pictures but the flash does not work on either. The flash worked OK before recharging batteries. I have recharged the batteries several times over the months and the cameras worked fine.
SOURCE: Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
SOURCE: Cannon Digital Rebel xt died will not turn on , recharged nothing
I think you have a faulty fuse (there are three in total) inside the camera. The fuse might have blown because of bent pin for the memory cards or a faulty cf card. In wich case, you have to repair it yourself, there are pages on the web that describe what you have to do (search for fuse and 350d), or send it to a canon service center ( they will change the complete motherboard because the fuses are soldered to the mainboard and they won't change them)
Sorry budddy
SOURCE: CANON POWERSHOT A300
If it's a short, not much that you can do other than try to track down the short location with a voltmeter. But I do have doubts that a short is causing this. The A300 is a notoriously power hungry camera. It's the first digital Canon to use two AA batteries. It takes great pictures, but unfortunately Canon didn't spend much time focusing on battery efficiency in getting the new two battery design out the door. As a work-around, try taking pictures by shutting off the display (press the DISP button) and using the optical viewfinder. Also the camera works best with high power rechargeable NiMH batteries rated 2500mah or better. Very inexpensive NiMH batteries are generally weak, and if no rating is shown on the package or battery, should be avoided.
SOURCE: Battery dies fast
There is no setting, that sounds just like a faulty Li ion rechargeable battery. Test the camera with alkaline batteries , if it works fine get a replacement rechargeable battery. Ensure that batteries are fully charged first.
SOURCE: camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
