SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
SOURCE: dc925 hammer drill wont drill a hole
try shifting the high/low switch to make sure fully engaged. Also make sure that all the other positions are correct and if so then you have a clutch problem. For a breakdown you can go to Dewaltservicenet.com and get a parts breakdown and list for this tool. Good luck and if I have answered your question would you please rate this response accordingly.
SOURCE: dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
SOURCE: Hammer-mode engagement
there should be a slider type switch on top of the drill. and there will be a picture of a hammer, and a picture of a drill. slide accross to the drill picture for drill, and hammer for the hammer drill
Testimonial: "Wow, thanks a lot, great service"
SOURCE: can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
