Brother Printer not activated error code 20 Is brought about by the inability to appropriately design the BROTHER printer on your framework. This blunder normally demonstrates when endeavoring to print a report, picture or spreadsheet on your PC, and after that, you choose to print that record with your BROTHER printer. "Printer not actuated - Error code 20"
There are a few reasons why the non-actuated Brother Printer Error Code 20 shows up, including the accompanying: The default printer isn't set to the printer you are utilizing.
·There's no printer driver accessible.
·Clashes exist in the gadget chief.
·Mistakes in the vault of your framework.
FOR MORE INFORMATION OR HELP RELATED TO PRINTER PLEASE VISIT ON GIVEN LINK:
https://www.brotherprintersupport247.com/blog/how-to-fix-brother-printer-not-activated-error-code-20
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When
you select Fax Forward, your MFC stores the received fax in the memory.
The MFC will then dial the fax number you’ve programmed and forwards
the fax message.
If
you select "Backup Print:On", the MFC will also print the fax at your
MFC so you will have a copy if there is a power failure before it is
forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed,
and then dials your Personal Identification Number (PIN). This
activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4.
If your pager needs a PIN, enter the PIN, press #, press Redial/Pause,
enter your fax number followed by # #. Press Menu/Set. (For example,
press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If
you do not need a PIN, press Redial/Pause, enter your fax number
followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0
0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
MFL-Pro
Suite software on your PC, make sure your PC is connected and turned
on. (For details, see Using Brother PC-FAX software on page 5-1 in
Software User’s Guide on
the CD-ROM.)
■ If you get an error
message and the MFC cannot print the faxes in memory, you can use this
setting to transfer your faxes to your PC.
Turning off Remote Fax
Options If you set the Remote Fax Options to Off and there are faxes in
your MFC’s memory, the LCD will give you two options.
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
Setting your Remote Access Code
The
remote access code lets you access the Remote Retrieval features when
you are away from your MFC. Before you use the remote access and
retrieval features, you have to set up your own code. The default code
is inactive code (--- ).
