HP LaserJet 3020 All-In-One Printer Logo
Abhay Posted on Nov 18, 2013
How to clear memory on hp 3020 all in one laser printer
Greg Knight
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Dec 03, 2013
Greg Knight
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
4323
Points
14
Clear the memory on the product.
Press the ENTER/MENU button one time.
Press the < or > button until Fax Functions appears in the control panel of the printer.
Press the < or > button until Clear Memory appears in the control panel.
Press the ENTER/MENU button one time to clear the memory.
Testimonial: "thanx Sir , I will try this.."
3 Related Answers
Anonymous
  • 87 Answers
  • Posted on Oct 30, 2008
SOURCE: Fax Memory full
please perform the following:
When a super NVRAM Init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM Init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM Init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Anonymous
  • 10 Answers
  • Posted on Dec 12, 2009
SOURCE: 10 % Memory problem showing my printer and slow
In the printing process, there a stage called spooling. This is where the data to be printed is cached into your system, so that you can print it even without having to leave the source application open. However, when you are low on RAM (or computer memory), the spooling and printing process slows down since the system is finding it hard to transport the data due to the bottleneck. Closing running applications (such as your web browser, music player, media player, games, and such) would definitely help ease out this one.
Anonymous
  • Posted on Feb 10, 2010
SOURCE: memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
How do I clear memory on Braun ThermoScan plus thermometer
  1. Memory mode.
  2. IRT 3020. The last stored temperature is displayed along. with the MEM symbol. ...
  3. IRT 3520. This model allows you to store up to 8 temper- atures. ...
  4. Memory clear. Press the /mem button for 5 seconds to clear. the temperatures stored in memory. ...
  5. LCD light (model IRT 3520 only) For easy nighttime reading.
https://www.manualsdir.com/manuals/50884/braun-thermoscan-irt-3020-thermoscan-irt-3520.html?page=9
How can i clear buffer on hp 3020 all in one laser
Why not let it complete remainder printing after cancelling the job.
You may also pause printing, remove most paper from paper trays so that it run out of paper then then power cycle the printer.
My HP-3020 does not work in Windows 7
Hi I think your printer is not well installed. Try to delete this printer from the "Computer setup" then download the right driver from here : http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378052&prodNameId=378054&swEnvOID=4062&swLang=8&mode=2&taskId=135&swItem=ja-45284-16 Click on "Download" After the download has been completed, try to install it.
I think the solution is very clear. if you have any question, feel free to reply to this message.
If you like my solution, please rate it. Thank you for using fixya
How can I clear my fax memory hp laser jet 3055
Hello !
You can clear the memory by doing an NvRam or hard reset
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
1helpful
go to advanced fax setup >>click on clear fax log..it will work
5helpful
Hp laser jet 3050 memory low does not allow me to receive faxes or even photocopy? What can I try to fix this problem?
Perhaps you could clear the fax memory.
Perform the following to clear the fax memory:
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
1helpful
3answers
Memory full hp 3055 laser jet
k24674
Grand Canyon Tech
Grand Canyon Tech
