I recently changed to a different telephone, had Earthlink make it ADSL active but could not get the DSL light to stop blinking - I've done everything Earthlink suggested and what I could find on the Internet but no luck. The line seems fine since the telephones work. I've connected with a filter/splitter and directly to the outlet.
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Testimonial: "Thank you - I did try it with and without the splitter and no difference. I am attaching it to one of the original phone jacks. Should I try one that was added later?"
SOURCE: DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC.
Type http://10.0.0.2 into a web browser (eg. Firefox or Internet
explorer) username/password is admin/zoomadsl go to basic setup and
input your ISP username and password (the one given to you by your
internet provider) under PPP. Click configure my connection. Save
changes and then write to flash (both buttons on bottom of page)
SOURCE: Zoom ADSL X5 dropping connection
It is a sure case of UR AC ADOPTER MALLFUNCTIONING. plz change your AC Adopter your problem will be solved.
SOURCE: no connection to internet
You need to do a reset to the router hold in the the rest buttons for 30 seconds.Then shut down the pc and try it again.
When it boots up see if there are any errors.
I also want you to go (command prompt) type cmd in the run box and type in just like this
ipconfig /all
see if an ip address comes up
then type in ipconfig /release
wait then type this
ipconfig /renew
Wait till it collects info then restart computer it should resolve after that its a communication error with the router and the pc.
1. Check the for the Physical connection Between the router and dsl the modem
2. And make the sure the dsl light or the status is solid green in the dsl modem
3. If the dsl light or link light is bilking on the dsl modem . call your service provided and run a line test to confirm if there is any problem with the telephone line
The X7N will go thur a slow blinking process, the a fast blinking process and then go solid. It may do this twice before it goes solid and stays solid. If you are not getting the fast blinking at all, you are not hooking into the server.
