How do I program my scannner, the code for police department in eatonton, georgia
SOURCE: scanners
Other than size of the scanners there is no difference. I used to think that a home Base station scanner would work better. This is not true. Every scanner I purchase now is a portable. I use them at home and even hook them up to an antenna on the roof. They work great and you always have a choice to take them on the road with you.
Your problem specifically sounds like it is probably a programming error. Take a look at you frequencies on Radioreference.com to make sure you have the most current. then look up in you manual the programming section in your manual and plug in the frequencies and it should work fine.
elijam1
http://www.scannermaster.com/?Click=37131
SOURCE: I have a older model uniden bearcat police
Hi Hun, sorry to hear of your lost, my condolence to you.
Try this link, scroll down just under smilie facel, ook free manual download. Or try clicking this direct link.
uniden bc-560xlt manual CLICK too download
SOURCE: dont no how 2 get police chanel or others thank u
look on the net for the Band plans of the country you are in.
SOURCE: programming a uniden scanner
Programming the 248 is fairly simple once you know the steps.
- Turn the scanner ON
- Press the MANUAL key to stop scanning
- Enter the channel number that you wish to program (01, 02, etc.)
- Press MANUAL
- Enter your frequency, including the decimal point (e.g. 156.055)
- Press E to confirm
- Press MANUAL to advance to the next channel
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, viksit:
www.RadioReference.com
