Question about Whirlpool Ovens
Oven will not maintain heat
Have a Whirlpool Imperial Series accubake freestanding electric range model # RF198LXMS. Seems to preheat ok as bake element glows and then goes off as temp is reached but oven will not maintain proper heat for cooking. Food does not get done. Stove top working fine. Any Ideas? David
    Top Expert:
  • Whirlpool Master
  • 53,765 Answers
Possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
Posted on Feb 28, 2018
6ya staff
SOURCE:
Ajith Kumar
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    jumptrout51
    steve
    • 3361 Answers
    SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
    Some gas ranges may take 10 or so minutes to light.
    Other than that you may have a defective glow bar ignitor.
    If it glows and does not light the reistance in the ignitior has failed.
    Posted on Feb 25, 2009
    dsims119
    SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
    I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
    318022002 is the part number for the relay board with transformer
    318022001 is the part number for the relay board without transformer
    Yes the one without the transformer is more expensive for some reason.
    The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
    To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
    NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
    Posted on May 13, 2009
    Anonymous
    SOURCE: GE True Temp Oven not heating. Broiler works
    we bought a new oven
    Posted on Dec 15, 2009
    Anonymous
    SOURCE: I hava Whirlpool Accubake oven model RBS245.
    DISPLAY READS E1 F5
    Posted on Jan 13, 2010
    How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
    first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
    Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
    The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
    It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
    Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
    Only preheats doesn't reach temp
    If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven wont heat up on bake
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    heatman101
    Jan 14, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven won't heat, display out, gas burners on stove
    Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
    Thanks
    May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven elements do not heat?
    The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
    Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Whirlpool accubake rbd245pdb no power to control
    Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
    If all check out ok with all the above, replace the ERC
    Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Broiler element Whirpool Accubake electric oven not working
    Hello
    Welcome to Fixya
    My name is Huum,
    You need a new top element
    http://www.pcappliancerepair.com/model-display.php
    You can find the diagrams,schematics, and parts for your range at this site
    Please remember to leave a rating before you leave
    Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
    Open Questions:
    Ovens Logo
    Top Whirlpool Ovens Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
