Home Logo
A
Anonymous Posted on Nov 17, 2013
Price pfister aerator screen fell out how do i replace it
5 Related Answers
Anonymous
  • Posted on Apr 26, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Anonymous
  • 145 Answers
  • Posted on May 23, 2010
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
Anonymous
  • 2080 Answers
  • Posted on Feb 13, 2011
SOURCE: Have a Price Pfister Marielle
More than likely you are due to replace the Cartridge inside the faucet.
It could also just be an O-Ring or a rubber seal is adjar in side the faucet assembly.
If you are handy with basic plumbing tools you can just shut off / drain the water and disassemble the faucet yourself to see if anything is obviously broken / torn / out of place. If it is not leaking anywhere around or underneath the faucet, then its unlikely you will have to replace the whole unit.
Here are some links to the documentation for your model from the Price Pfister Online Support page including links to instructions and parts diagrams:
http://www.pfisterfaucets.com/trade/product_catalog/Product/T34-3TSS.aspx#
Here is a link to a parts explosion diagram:
http://www.pfisterfaucets.com/www/ImageAssets/mirror/model/kitchen/marielle/mart34-3t/ex-034-06.pdf
Here is a link to the instructions (see page 7 figure 26 for Cartridge replacement instructions):
http://www.pfisterfaucets.com/www/ImageAssets/mirror/model/kitchen/marielle/mart34-3t/28588-0400.pdf
If you just need a new cartridge then just bring your model number into the store where you purchased it and they can provide you with the right part for you to install yourself.
Otherwise you will have to call a plumber and pay him an hour's labour to do it.
Good luck and please comment back and rate if this was helpful at all.
Thanks.
Joe.
Anonymous
  • 3 Answers
  • Posted on Oct 27, 2012
SOURCE: I have a Price Pfister
You need an aerator wrench, Pfister part number 941-031. Several vendors on the web carry this part.
Anonymous
  • 3 Answers
SOURCE: how do you unscrew the aerator housing from the
How do you remove the aerator housing from the Price Pfister hanover double handle bathroom sink faucet
most aerators are screwed into the faucet
IF you use a pair of multigrips with clothe folded in the jaws , you can apply gentle pressure and turn it out
too much pressure and you will distort the aerator so be gentle with it
Water shoots out of my faucet, now can I plug it?
water is supposed to come out of your faucet...in a controlled fashion....if its at the handle....remove the handle and locate the source....tighten the packing gland or replace a seal. if it sprays all crazy at the spout...try unscrewing the little piece on the tip of the spout (aerator)....flush your faucet by running the water with it off...then flush out the screen on the aerator and re-attach it...hope I was some help....good luck and always know where and how to turn your house water supply off before working on any pressure points on your water supply system.
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
3helpful
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
3helpful
2answers
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Top Price Pfister Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
