Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Mine never turns green, always stay orange when on. As for the vapour, i add a little salt to the water and it works wonders, just about a tsp... good luck!
You just turn the switch to off and let it sit for a few minutes. Then when you turn it on again it will be green. I turn it off when I take the tank off to fill it and by the time I return, it has reset.
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem
Humidifier power light is staying red and
not turning green
Humidifier is working than stops:
? Solution
Ensure that water level sensor is
assembled properly.
? Clean water float
? Call service center and request
replacement water float
If humidifier does not work at all: ? Ensure it is properly plugged into a
power outlet.
? Check that the switch is in the ON
position.
? If Power On indicator light does not
come on, bring to authorized service
station.
there will be a water level sensor at inside wall try to fix it .it also seem to be a power failure case well since you have just got it must in warranty or free service utilise it. If you like my suggestion then vote for me i will be thankfull
FROM TROUBLESHOOTING SECTION OF MANUAL:
not turning green
? Ensure that water level sensor is
assembled properly.
? Clean water float
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
According to the Crane's Troubleshooting section: The power light is green but there is no mist being emitted: - Check that there is water in the tank. - Check for possible lime deposits on the water level sensor or the nebulizer. - Make sure that nothing blocks the vapor output slots. - Check that the fan vent on bottom of humidifier is not blocked. - Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant. Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops: - Ensure that water level sensor is assembled properly. - Clean water float. - Call service center and request replacement water float.
Barring that, here is the service center contact info: Dart Warehouse Corporation Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct) Website: http://www.crane-usa.com 1835 Ferry Road Naperville, Illinois 60563
