Question about Pioneer EQ-6500 9-Band Car Equalizer
Input -output connection - Pioneer EQ-6500 9-Band Car Equalizer
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    How can I connect some device to my TV?
    In order for this to work, there must be INPUTS on the rear of the TV corresponding to the red, white, and yellow OUTPUTS from the device. You have video input so that means the Y output from the device probably is connected correctly. This leaves the two audio outputs: red and white. Connect the red output from the device to the red (right) input of the TV. Likewise, connect the white output from the device to the white (left) input of the TV.
    Mar 19, 2016 | Televison & Video
    How do i connect my z5610 to my hd tv there is no hdmi or vga output on the pc
    > no HDMI or VGA output
    Every PC has either one DVI or one VGA output.
    Does your z5610 have a DVI input? If so, connect the DVI-output to the DVI-input.
    Or, add-in another video-card that does have HDMI output, and connect HDMI-output to HDMI-input.
    Mar 06, 2011 | Computers & Internet
    How i can connect the tv as my computer moniter
    Does your TV have a "VGA" input? If so, then connect the VGA-output from your computer's video-card to that VGA-input.
    Does your TV have a "DVI" input? If so, then connect the DVI-output from your computer's video-card to that DVI-input.
    Does your TV have a "S-Video" input? If so, then connect the S-VIdeo-output from your computer's video-card to that S-Video-input.
    Note that only _SOME_ video-cards have DVI output or S-Video output. Check your video-card.
    Dec 01, 2010 | Computers & Internet
    Mixer and an EQ & amp ?
    The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
    Jun 23, 2010 | DBX 1215V Home Equalizer
    Component input no HDMI output
    The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
    Apr 15, 2010 | Marantz SR5001
    How do i connect yamaha mixer to pc or yamaha receiver
    I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
    Dan
    Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
    Does this system have a optical input
    Here are the list of connections on this system
    • Audio inputs/outputs 2 analogue input sources,
    1 analogue output connection
    - TV : in
    - VCR : in
    - CDR : out
    - Headphone : 3.5 mm
    • Digital audio in/output : 2 digital output connection
    (coax, optical)
    • Video outputs : 3 output connections (1 S-Video)
    - TV : out
    - VCR : out
    - Monitor : out
    • Speaker Connections suitable for speakers ≥ 6 Ohm
    - left, right, center : click-fit connection
    - rear left, right : click-fit connection
    • Miscellaneous connections
    - TV center speakers pre-out : 1
    - Subwoofer pre-out : 1
    - AM antenna : loop type
    - FM antenna : coax
    please mark this fixya if it has answered your question.
    Dec 14, 2009 | Philips LX3000D System
    Help fixing a sound problem with our receiver
    You should be able to find all the instructions for these connections in your products owners manuals. The procedure should be straight forward. all the connections to the receiver should be input and output connections. The Receiver is basically just a switch box and amplifier with extras.You must make sure you know which input and output you are using for each of the components. You must have all the remote controls set-up to work with each other. The receiver is the master switch. From it you will control all input sources to the various output sources. Here is a possible set-up . Television output sound and video to the first input/ output section of the receiver. from here you can use the first audio/video output to your dvd/vcr input. This will allow you to record the television programs video and audio to your recording media.The audio/video output of the dvd/vcr will be connected to the second input /output of the receiver.With the second input you can view all the dvd/vcr materials on the television while listening to the sound through your receiver.The master output of the receiver's audio/video output is connected to the television input circuit. This will allow viewing and sound from all the units connected to the receiver. The receiver sound system will receive sound from all the input units as long as the connection are right and the input/out selections from the remotes controls are correct. That is the reason the owners manuals are so important for this purpose. They give these instructions and diagrams to show you the correct procedures for setting them up.They also give you information about customer support either with website help or a call in line for technical assistance.I hope this helps you with your problem.
    Feb 09, 2008 | Audio Players & Recorders
    Pioneer EQ-6500 9-Band Car Equalizer Logo
    66 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Marvin
    Marvin
    Sumeet Sodhi
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
