Dryers Logo
Posted on May 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Amana LEA50AW. My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th press of the button. Then it just sits quiet. If I let it sit for awhile and push the button again it will hum. Could this be a fuse or the motor?
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on May 05, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
26694
Points
168
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
2helpful
A buzz sound when pushing start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Drum not turning
Kenmore dryers heavy duties80 series
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
1helpful
Kitchen Aid dryer hums when start button pushed. I can get it to run if I physically spin the tumbler and if there is a very light load inside.
7helpful
3answers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 • Dryers
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 • Dryers
Top Dryers Experts
john h
