Akai PT4799HD Rear Projection Television Logo
Posted on May 05, 2009
Pt4799hd akai projection tv is all orange
The screen is all orange and i believe the blue bulb isn't working and i was told that i would have to change all three bulbs, filters, and liquid and that it was not worth it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
2495
Points
23
Check the brightness control on the three colors controls, they could be off.
Where can i get a akai pt4799hd replacement bulb
Tries website Tv repair World.com,Ebay.com to buy the bulb.
Where can i get a replacement screen protector for my akai tv 47 inch rear projection
Not replace able,beacuse the DLP screen cost the same as a new not including labors.Tv not worth it to just replaced the screen.
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
1helpful
2answers
Where can i get a convergence chip for PT4799HD akai tv?
I'm fairly certain that particular Akai model contains Samsung parts. You can contact Samsung at 1-800-726-7864 to check pricing and availability of the part you seek.
Convergence. seeing three colors at once
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Akai PT4799HD - Bluish and Distorted Screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
2answers
1helpful
Akai pt4799hd service code
STK392-110s Do Not hold up some get so hot the pins fall off of them, USE STK392-180s always replace Both of them!
SERVICE CODE - Press Mute-1-8-3 with set on !
OK now use vol- and vol+ and ch- ch+ to adjust up&down-------- mute to stop where you need to ajust Press menu to adjust When done with alinement Press ADD to save your adjustments/ to change colors (7)sets RED (8) GREEN (9) BLUE.
Akai tv has failed to work
There are many circuit areas inside a TV set that can have burning components. Since you describe a colour change, I would think the fault may be in the video processor, screen biasing, or video drive path.
Jerry G.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
