Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
- Turn on treadmill, put safety key in place
- Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
- Use the SPEED + key to navigate to En93.
- Press ENTER once.
- Press START to choose unit (miles or km). The display will change accordingly.
- Miles: 0
- Km: 1
- Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press
START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
