Not sure this is enough, but here they come:
Delete settings:
Choose the wrench tab (top of the menu page) then choose delete settings. then press the (set) button.
Delete camera settings:
In the same menu tab, you also find delete the camera settings.
There press the (set) button. This will change everything you ever changed in the camera, back to the initial settings. I could not find e general reset.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
