Hasbro Catch Phrase Electronic Logo
r
rhylee munsell Posted on Nov 17, 2013
How do i turn on guess who - Hasbro Catch Phrase Electronic
A
Anonymous
05 b-21 keeps blowing fuse
Diesel car, is it or TRUCK, on the wrong forum?
2005 what is it? has no makers name or model>
must we guess 100,000 models of car and country too?
a post so extreme vague even mighty google can not decode your post. wow.
you have a short.
and best is service manual
as some fuses run 10 things.
guessing will be hard, due to that one hard fact.
wild wild guess
Kubota B21 Tractor.
a tractor"??????
B21 too is VOLVO
I guessed B21 is an engine,
yes engine matters for fuses and transmission in fact the whole body type, doors, and 4wd or AWD and a huge list here/ not told by me ever.
Kitchenaid KEMS308SSS00: when I open the microwave door now, instead of light coming on, the turn table turns!
It's a guess, but something mis-connected on that new board. They usually have a number of edge connectors and you have two on the wrong pins. A guess never the less.
I have a 1997 mercury grand marquis gs V8 that isn't starting, it will make a loud click noise when the key is turned to start it but will not turn on. Battery is good, alternator is good, spark plugs are...
If it is clicking when you turn to start, the solenoid is sending power to the starter. It sounds to me like the starter has a problem, maybe a connection or the starter itself. Hope this helps you out.
How do I stop the hazard lights coming on when the car is turned off. They only go off again when the ignition is turned on again.Car is a Suzuki Swift 2008
it needs service, is for sure......
is this a DIY diagnosis question (tests to do)?
or a question for wild guessing..?
we in USA on this USA forum do not have 08 swifts, here.
(no books)
so best help would be joining a suzuki forum that covers your unstated country. for best answers,and most timely, and not wrong do to those facts.
after all my books and online sources are all USA spec cars.
no guess:
check all fuses.?
first do a full pcm scan at the 16pin port, look for DTC errors.
post them.?
guessing ?
my guess is the hazard switch is failing?
or BCM brain is scrambled.
not doing the scan misses the boat.
even the Titanic. (?)
When I turn on my kenwood it automatically turns off
First guess I have is you have speaker wires crossed or shorting out against each other, check your speaker wiring make sure no bare wires are touching each other, most amplifiers will automatically shut off if it senses a short. It doesn't specify, but i am taking a guess this is a amp/receiver
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
All electric apt 5 year old fan wont turn off when air is off
Sound like bad mercury switch or time for a new thermostat would be my first guess, second guess would be that the condensing unit needs to be cleaned out side. it might be frozen up, that happens when it gstarts getting hot outside.
It might also just be as easy as flipping the breaker to the unit to allow it to reset and turning it back on. but if its still cooling and just wont shutt off, my guess would be thermostat or lose wire in there of.
If you dont have a maintenance guy you can call and it is too cool, try turning the breaker off at night until you can get it looked at.
How do i put a guest on my laptop?
Windows usually has a Guest account already setup, but it maybe TURNED OFF.
Gi to Control Panel - User Accounts - then look at the Guess account, if it is turned off the click on the Guess account and then click Turn On.
If there isnt a Guess account the you can create a User with Guess Privileges.
The distributor on my husbands 99 Nissan Quest stopped turning. I'm guessing that it is broken. Is this expensive to replace
most likely timing belt failed.this turns camshafts which in turn rotate distributor.fotunately for you ford insisted nissan make this a non interference engine during their joint venture with mercury villager.so no internal damage should have occurred.im guessing about 700.00 to replace timing belt,water pump and drive belts.
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
