NetGear WGT624 Wireless Router Logo
r
richard walls Posted on Nov 16, 2013
Netgear wnd3700v3 has two yellow linght on and no internet
Riff Raff
Level 1:
Habit-Forming:
New Friend:
  • Contributor 42 Answers
  • Posted on Nov 17, 2013
 Riff Raff
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
42
Questions
0
Helped
10675
Points
96
The internet port of the router needs to connect to the modem from your ISP. The two yellow lights are normal but if the internet light is off check the cable from the router's internet port to your modem.
Sometimes the modem needs to be turned off then back on again for the router to get an internet connection (IP address).
1helpful
2answers
Netgear streaming player
Sounds as if it has found an open Wi-Fi connection, but the device it is connecting to doesn't have an internet connection.
Make sure the Netgear player is connecting to your wireless network, and that you have a live connection to the internet.
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
I have 4 pots and 1 yellow where do i put my
Well you have netgear wireless router.On the back side you have 4 ethernet port where you can plug a cable which is coming from telephone.Its up to you if you want a wireless and your computer don't have a wireless adapter then to get a wireless connection you required a wireless adapter.Ya you can use internet connection with erthernet cable also
Hope this will resolve your issue
My netgear will not let me connect to the internet via my wireless connection my main computer has internet as it is connecter via the yellow cable to the netgear my other computers have a netgear adapter...
Open Zonealarm, choose Firewall, Zones.
Add >> IP Range set your IP range eg 192.168.0.1 to 192.168.0.254
This should allow connection between Router and Wireless Laptop/Desktop.
If your wireless PC cannot see the router, check your router setting to see if you are transmitting a SSID
The light of internet is orange,not yellow.
The router should have reset button on the back. This will reset it to factory defaults. If you have an ISP that gives you internet without a username and password like rogers then you should be good to go. If your ISP is like Bell then you will need to get into the website of the router and configure it.
New ;laptop
You mean you want wireless internet? You need a wireless router, then you need to go into the setup to set it up @ 192.168.1.1
Router does NOt connect
why not you can connect the internet. first you tell me how much mbps now you using ?
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
