Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: cartridge not installed message
This worked for me
Each toner cartridge has a small green chip with 3 gold-colored contacts on it. First thing to try is to rub those contacts with an ordinary pencil eraser. You will need to rotate the toner carousel to get to all 4 sets of them. To get it to rotate, there is a little square-ish hole in the white plastic housing to the right of the toner cartridge that is visible when the top cover is raised. Push a pen down in the hole, which will push on a tab allowing you to rotate the toner carousel until you can see the next cartridge. Repeat for all four toner cartridges. Close up the printer, power it up, and see if it solves the problem. If not, do this: Remove the drum (gently pull on the green handle). Be careful not to touch the roller or let it contact anything. Get a flashlight, look down inside the printer on the right (it's kind of hard to see, it's almost under the toner cartridge). You will see a black sensor switch with three wire-like contacts, surrounded by a square white housing. Wipe off those contacts, if you can get the eraser in there better yet. Contacts are kind of flimsy, be VERY careful you do not bend them. Next, take the point of a pencil and push on each contact, it should move in and return when released. If that seems good, put it all back together and try the printer again.
