SOURCE: Port Forwarding for Apache Server
Hi Robmoll,
Let's get a little bit more in detail. I'm doing the same exact thing you are trying to do with a D-Link DI-624 and I'm using NO-IP instead of DynDNS. I'd like to ask you a question, if I may, what are you actually seeing now using port 80 and how did you disable it? Can you connect another PC to the same router (making a small Home Network) and test locally your Apache and eventually your web-page by typing something like this "http://192.168.0.101/"? Are you already able to see your router from the "outside" trough port 8080? Are you specifying your "private" IP in the port forwarding setting of your router? Do you mind showing a snapshot of your port forwarding settings? Here is mine; you see two different IP's because there are two PC connected.
Regards,
GiBi
