Televison & Video Logo
Brian Mathis Posted on Nov 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Comcast remote I cant find the correct code for this tv, help please.
John
Level 2:
Scholar:
  • Expert 140 Answers
  • Posted on Nov 16, 2013
 John
Expert
Level 2:
Scholar:
Answers
140
Questions
Helped
28382
Points
285
Read the comcast instructions and do a 'Search' for the code rather that trying to look it up on the list. It takes a few min but works every time for me.
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
2answers
Tv code
You can refer to this website and get all the details of comcast
http://www.xdiv.com/remotes/
I HAVE A APEX TV MODEL AT2702S AND I HAVE A COMCAST REMOTE AND I CANT FIND THE CODES TO SET UP MY TV WITH THE REMOTE PLEASE SEND ME A CODE THAT WOULD WORK....THANK YOU
In my case,
the Comcast remote code that works
for the Apex AT2072S
is 10156.
So more than likely the Comcast remote code for the Apex AT2702 is 10156.
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
3helpful
Comcast remote will not work my emerson tv
Each remote has a different code usually. So you cant get one from me, or anyone else. What you can do is call the comcast company and tell them your problem they should be able to give you a better explanation.
What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
0054
1454
0690
1154
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
10054
11454
10690
11154
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Ed
Cant find correct magnovox 47mf439b code to use with direct tv remote
I have the Magnavox codes as listed for my Comcast remote and possibly one of these will work for you. ( 0054, 0030, 0179, 0186 )
I have the same TV as you and 0054 worked for my Comcast remote.
Good Luck!
80helpful
6answers
3answers
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
