Dryers Logo
charleskerns Posted on Nov 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much will 4 cfl 26 watt bulbs run me monthy on 24 hrs.
John
Level 2:
Scholar:
  • Expert 140 Answers
  • Posted on Nov 16, 2013
 John
Expert
Level 2:
Scholar:
Answers
140
Questions
Helped
28410
Points
285
4 x 26w = 104w x 24hrs = 2496whrs x 30 days = 74880whrs
divide that by 1000w and that's 74.88 Kilowatt hours.
Now look at your electric bill and find out how much you pay for a Kilowatt hour, multiply that cost by 74.88 KwH to get your cost per month.
1 Related Answer
Anonymous
  • Posted on Oct 07, 2008
SOURCE: CFL bulbs for fan fixture
I had a simple question and you wanted me to pay you to answer it.
I am still hoping to get a CFL lightbulb with socket size E17 to provide more light for my kitchen, but you won't help.
Screw you all.
Sherwin
1helpful
What type of light bulb do I need for a minkaAire ceiling fan. It is about 7 years old
It all depends on which light kit was installed on your fan. As you described the fixture as requiring a "light bulb" meaning a singular bulb, Minka Aire usually uses several different types.
The most common is either a 40-watt or 60-watt Candelabra Bulbs.
(The designation "Candelabra" refers to its screw base. You can buy these in clear or frosted, torpedo or globe with a straight tip or curved. Etc.
Here's an example of a torpedo globe:
Sunlite 60 Watt Torpedo Tip Chandelier Candelabra Base Frost 48 Pack
And here's an example of a Candelabra globe:
Sunlite 60 Watt G16 5 Globe Candelabra Base Clear 48 Pack
Some of their fixtures use a 50-watt Mini-Can Xenon Bulb.
Satco S1914 50W MINI CAN FROSTED 120V
And other use a 3w CFL Medium Base Bulb.
3W CFL Deco 2700K Medium Base
When installing a CFL, Halogen or Xenon bulb, I recommend cleaning the glass with an alcohol wipe to remove any oil from fingerprints. Due to the very high temperatures these lamps operate at, the oil from your fingers will cause a hot-spot on the glass and can shorten the life of the bulb dramatically.
If none of the references I offered match the bulb in your actual fixture, you might be able to more closely match the fixture from one on the following page. The recommended bulb for each fixture is listed in the description of the fixture.
https://www.ceilingfan.com/Minka-Aire-Fan-Lights-s/2082.htm
And as always, NEVER over-lamp a fixture with a bulb rated at a higher wattage than what's shown on the base of the fixture. That is, never use a 60-watt bulb in a fixture rated at 40-watts. The additional heat of the bulb may harden the insulation of the wiring in the fixture creating, causing the insulation to fail and create a fire hazard. Also for fixtures located tight to the ceiling, higher temperatures can dry out the gypsum ceiling material, causing it to crack and deteriorate.
Feb 09, 2018 • Dryers
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
EJ351 is programmed to work. In the on position the light it controls is on properly. in the automatic off position the light is on at approximately half intensity. When the manual control is in the o
This timer is rated for incandescent light bulb only.
With 40 watt minimum.
With 100' maximum distance between bulb and timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej351
EJ351 is not rated for CFL bulbs (or motors etc).
CFL bulbs are considered inductive loads (same as motors), while incandescent bulb is resistive load (same as a heating element).
Both types of loads use electricity differently.
Programmable wall timers are not ordinary on-off switch... unless you use the override switch.
... instead timers control electricity with electronic circuit board.
So when the manufacturer designs the electronics inside the timer, the design must anticipate how the electricity is used by the load.
Older designs like EJ351, and some modern timers, are not rated for CFL.
... however most newer timer designs are rated for both resistive and inductive loads.
Always read the specification sheet for load rating before installing programmable timer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
1helpful
2answers
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 • Dryers
1helpful
1.Is the 9-watt cfl bulb replaceable and if yes which stores
The bulb is replaceable. You can get the bulb at radio shack and also from the company website.
Top Dryers Experts
john h
