Dear
you need not update firmware for this model. Pl. do the printer status monitor(SMART PANEL). Down load from samsung site and run inpc application. when print command given it will display the problem.
Thanks.
Are you sure it needs one? What's it doing wrong? If it has a firmware available, it would be on the Panasonic website. For more information, please visit my website at audioserviceclinic.com. Thank you.
I would have to know your model number, but if there is any firmware available, it would be on the Panasonic website. Bare in mind, not everything needs or should have a firmware update. What is it doing wrong? For more information, please visit my website at audioserviceclinic.com. Thank you.
You need to use a ohm meter (you can get one cheap) and find out if the power switch is working. You can also determine with it if the power is getting into the turntable. If the switch is working and power is getting to it, then either the transformer has failed or something is wrong in the power supply section.
Hi Tim, I know your post is a year old but I'm hoping my massage reaches you. Can you please email the firmware update for studio 282 as well? Thank you [email protected]
Could you tell me exactly what the error says inside windows media player? before you reply back update the firmware on your device...You can go site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
**Si vous voulez vous pouvez me contacter sur mon [email protected]
Merci...**
Install the firmware update that comes with the player. The solution is as simple as that. I had the same problem - the player was switchin off on its own. I installed the firmware update and it works like a charm. :)
