Haier HL47K 47 in. LCD TV Logo
Kenneth Ingram Posted on Nov 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the composite connection for
Trying to connect to a audio system
John
Level 2:
Scholar:
  • Expert 140 Answers
  • Posted on Nov 16, 2013
 John
Expert
Level 2:
Scholar:
Answers
140
Questions
Helped
28415
Points
285
It is a analog video out or in, RCA Jack.
2helpful
2answers
Can you please tell me how to connect my Humax 9200T PVR to my Onkyo TX-SR608. The Humax does NOT have HDMI connections and the manual does not mention the connection of a PVR. The Humax Manual is of no...
You will need to purchase a scart to HDMI converter - available in the UK for about £40.
If you Google 'Scart to HDMI converter' you should find several options, which will be cheaper if you are in the US!
Unfortunately the Humax box you have only supports Scart A/V I/O, which is of course now obsolete.
1helpful
I am trying to connect a wii to an onkyo tx-sr304...i have a directv satellite box and a DVD player connected to the component Video 1 and DVD connections and using to connect component out to TV...trying...
The pecking order for output video to your monitor forbids a lower quality video (composite (Yellow) being up-ticked to anything higher (your component out) (Page23).
The wii would be visible on the Monitor Out composite output (Page 24) to the TV.
3helpful
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
The new AV cable will not fit into the slot in the ps3. Used a regular composite cable prior to trying the new HD cable.
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks .
click here to download repair guide... u can do this by yourself....
1helpful
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
I cannot get the surround sound to come on tv mode on my friends RCA DLP. Any suggestions? is this a t.v. issue? DVDs and Ipod connections are fine.
The tv must have a stand alone audio output that you would connect the audio composite cables to going to the aux or audio input of the surround sound system. You may need to switch the surround sound system to aux mode or av input 1 or 2 and etc. If you are connecting a cable box or satellite tv box to this television instead of connecting the audio composite cables between it and the tv, connec them between it and the stereo surround sound system.
2answers
Conection to tv problem
gerardali,The question is what input connection do you have on your TV?
Your Venturer has three types of video outputs:
1) Composite video (single yellow RCA)
2) S-video (single 5 pin cable)
3) Component (3 cables-red, green & blue RCA's).
The component will give the best picture but not all TV's have this connection. The second best is the s-Video but again not all TV's have this connection either. The composite is the lowest quality and the most common available connection.
Make sure that you are using the same audio and video inputs on your TV; such as, if your audio is going in AUX 2, make sure your video connection of choice is going into AUX 2 also.
-Chris
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Connecting an hd-tv
use optical or composite digital audio cable only from tv to receiver because with rca (red and white) you get stereo only
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
