Try this
Access Startup Settings
When the Choose an option screen appears, click or tap the Troubleshoot tile.
Next, click or tap the Advanced options tile.
Select the Startup Settings tile owindows 8 wont recognize datel game controller - windows-8-startup-settings.png
Click the Restawindows 8 wont recognize datel game controller - windows-8-startup-settings-restart.pngen to reboot your computer again.
Disable Driver Signature Enforcement
On the Startup Settingwindows 8 wont recognize datel game controller - windows-8-disable-driver-signature-enforcement.png select the "Disable driver signature enforcement" option.
Windows 8 will immediately boot to its typical lock screen. Sign into Windows 8 as you normally would - everything will look the same, except Windows will no longer demand driver signatures until you next reboot.
You can now install unsigned drivers as you would on previous versions of Windows. Wiwindows 8 wont recognize datel game controller - install-unsigned-driver-anyway-on-windows-8.pngiver that isn't properly signed, but you'll see an "install this driver software anyway" option you can choose.
Reboot
When you're done installing the unsigned drivers, reboot your computer. Windows will keep using any unsigned drivers you've already loaded, even as it enforces signature requirements for new drivers.
