Question about Lenovo R61 T7300 Notebook
Bluetooth device driver is installed but doesn't recognized
When double click on the bluetooth icon a message seen which is bluetooth device is not recognized but id does appear in device manager.
    Problem Solver:
  • 7 Answers
From device manager, right click on the bluetooth device, and select uninstall. Then go the hardware manufactures website and download the bluetooth drivers for your product. Install/reinstall the drivers, then go to your control panel, and scan for hardware changes. It should detect the device, and want to install with the new/refreshed drivers you loaded.
Posted on May 04, 2009
  • 560 Answers
Make the device discoverable. Access your Bluetooth-enabled device's settings page, and turn on the device's 'Listen' or 'Discoverable' function to allow you computer to find it.
Posted on Sep 17, 2012
6ya staff
SOURCE:
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
Tip
USB Printer does not recognize with XP Computer
In most cases, the driver for a printer is supplied when you purchase it. It is the responsibility of the manufacturer to provide the driver along with the device to make sure the working.
However, most of the Operating Systems come with native driver support for many known printers. This is the fact we have to take care while purchasing a printer. Even though we misplaced the driver disc, if we purchase a good manufacturer printer, there is a chance to get the native support from Operating System itself.
There are some scenarios where printer may not be recognized by the Operating System due to some conflict with other devices.
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:WINDOWSI386 folder.
  • Remove and reconnect the printer.
does not recognize printer XP computer does not recognize printer. HP printer computer connectivity how to troubleshoot if printer is not connecting to my computer. XP printer issues. how to troubleshoot printer conncting with XP Computer. XP does not recognize printer. Printer is not connecting to my computer. how to reinstall printer driver. how to install native driver for printer. CANON printer is not recognized by the Computer. Epson printer is not recognizing. Epson does not recognize XP. Canon Printer connectivity.
on Jan 27, 2011 | Office Equipment & Supplies
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
How to activate bluetooth in a leptop
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
Dec 13, 2012 | Lenovo 3000 N100 Notebook
My philips gogear 4gb mp3 player is nt startin what 2 do??
I'd suggest that you format your player or repair it using Philips songbird or device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Mar 16, 2011 | Philips GOGEAR SA6045 MP3 Player
Lg will not recognize bluetooth device
Hi friends
Do you want to CONFIGURE BLUETOOTH WITH COMPUTER ?
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Feb 20, 2011 | Computers & Internet
My laptop have got a build in bluetooth but i dont know how to connect it please help
hi
  • Open your computer's Control Panel center to access your Bluetooth Device settings. Click on the Windows icon or the "Start" icon on your computer desktop's taskbar at the bottom of the screen. When the pop-up menu opens, click on the "Control Panel" link.
  • Step 2 Access your Bluetooth Device settings. When the Control Panel opens, click on the settings link that reads, "Bluetooth Devices." This link will display all of the possible actions and settings you can take regarding your laptop'smag-glass_10x10.gif Bluetooth technology.
  • Step 3 Configure your laptop's Bluetooth technology. Select the "Start the Bluetooth Device" action. The blue and white Bluetooth icon will appear in the Windows System tray within the computer desktop's taskbar.
  • Step 4 Network with another device in order to import and export files. Double-click on the blue and white Bluetooth icon on your computer desktop's taskbar. A Bluetooth dialog window will appear on your screen displaying your Bluetooth technology portal. Click on the "Add Devices" action. You will then be asked if your laptop would like to search for other compatible devices. Click "Next" to proceed. You will be prompted to choose a passkey for the pairing. Create a simple passkey and click on the "Pair" option. When the notification is received by the other device, enter the same passkey to pair the device to your laptop.
  • Jun 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Lg vu
    User must be logged in as Administrator or have administrator privileges to modify system files
    Setting up the handset
    1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
    2. Touch the Settings icon located on the bottom of the menu tabs.
    3. Touch the Bluetooth icon.
    4. Touch Turn On.
    5. Touch Settings.
    6. Touch My Device Visibility.
    7. Touch to select On.
    8. Touch Set.
    Setting up the connection
    1. On the PC, double click the My Bluetooth Places icon on the desktop.
    2. Click View devices in range.
    3. If the handset does not appear, click Search for devices in range.
    4. Right click the icon representing the handset and click Pair Device.
    5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
    6. On the handset, an Accept? prompt will appear, touch Yes.
    7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
    8. On the PC, return to My Bluetooth Places.
    9. Right click the icon representing the handset and click Discover Available Services.
    10. Double click the Dial-up networking icon.
    11. When the connection window opens, click Cancel.
    12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
    13. Click the Modems tab.
    14. Click to select Bluetooth Modem and click Properties.
    15. Click the Advanced tab.
    16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
    17. Click OK.
    Making the connection
    3. Right click the icon representing the handset and click Discover Available Services.
    4. Double click the Dial-up networking icon.
    5. Type ISP@CINGULARGPRS.COM in the User name field.
    6. Type CINGULAR1 in the Password field.
    7. In the Dial field, type *99#.
    8. Click Dial.
    You will now be connected to the AT&T data service
    NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
    Apr 22, 2009 | LG Vu CU920 Cellular Phone
    Tosiba Satellite A205-S4577
    move your mouse to the left hand side of the screen and an icon will slide out for the webcam buttons...
    Oct 09, 2007 | Toshiba Satellite A135-S2276 Notebook
    Open Questions:
    Lenovo R61 T7300 Notebook Logo
    186 people viewed this question
    Top Lenovo Computers & Internet Experts
    Alun Cox
    Ekse
    Toby Lee
    Toby Lee
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
