Uniden DECT 6.0 Cordless Phone ID Logo
k
kathy frezell Posted on Nov 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Area code not coming up on the dect 6.0 and do not know how to record greeting on the dect 6.0 digetal answering system
Area code not coming up on phones and can't record greetings on the dect 6.0 digital answering system
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Nov 14, 2013
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443078
Points
622693
What model Uniden DECT 6.0 system?
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
1helpful
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
5helpful
2answers
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
How do I change the message... we set it a few years ago...can't find book
Oops, I posted the info for this on the VTech problem below sorry.
To change the message, first make sure your phone has the correct date, time, year, am or pm, etc.
Now, to Record Greeting - if you don't record your own greeting, a pre-recorded greeting message is used.
So, try this:
1. (Menu) press
2 (Go to Answering Device" with up/down arrow, press OK
3 (Go to "Record Greeting" with up/down arrow, press OK
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the
microphone.
5 To stop recording, press (OK)
6 (OFF)
Hope this helps.
1helpful
I lost manual. I need to know change message when will be out of town answering message.
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
7helpful
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
68helpful
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
8helpful
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
3helpful
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
