Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
A
Anonymous Posted on Nov 14, 2013
My new Kohler cimmeron toilet won't stop running.
It flushes fine...then there's a small stream dribbling in on the sides.
1 Related Answer
Anonymous
  • 63 Answers
  • Posted on Mar 16, 2009
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
We have tiny air bubbles in our brand new Kohler tank. We also have tiny streams of water constantly flowing into bowl. It's super quiet while the tiny streams run in the tank, not making the sound o
watch the mechanism after you flush. If the opening that lets water into the bowl does not close snugly, tiny stream will continuously flow. Make sure it closes properly.
Mar 24, 2014 • Kohler Home
Not enough water goes into the Toilet Bowl, The Tank fills up fine but very little goes into the Tank, Terrible Flush
THERE ARE LOTS OF SMALL HOLES WHERE THE WATER COMES OUT OF IN THE RIM OF THE TOILET BOWL, SOME TIMES HARD WATER BLOCKES THES AND THEY NEED TO BE CLEANED. THEY CAN BE CLEANED USING A LARGE SEWING NEEDLE, PUSHING IT INTO THE HOLE UNTIL IT FEELS A BIT BIGGER, YOU WON'T DO DAMAGE AS IT IS VERY HARD METERIAL. a
AFTERWARDS TURN OFF THE WATER, AND LIFT THE VALVE AT THE BOTTOM OF THE TANK AND PUT SOME TOILET ACID INTO IT. THIS WILL ALSO HELP CLEAN THE HOLES.
We just installed the Cimerron two piece. After flushing the toilet, it will not stop running. Water just goes into the over flow section.
  • The exact cause of a Kohler Cimarron toilet running non-stop depends on the exact model of toilet owned. In some, the lift chain connected to the handle can become kinked, preventing the ball seal from covering the drain completely. Just unkink the chain to fix this. In other cases, the float ball is stuck against the side of the tank, preventing it from returning to its normal horizontal position. When this happens, the toilet's tank doesn't stop filling with water. The excess continuously flows into the overflow pipe. Dislodge the float ball from the side of the toilet and this should clear the problem. Likewise, you might consider shortening the armature on which the float ball sits, so it won't become stuck again.
  • Read more: Troubleshooting a Kohler Cimarron Toilet ' eHow.com http://www.ehow.com/how-does_5017443_troubleshooting-kohler-cimarron-toilet.html#ixzz1CxKmz9ZQ
    Feb 04, 2011 • Home
    1helpful
    Float does not trigger valve to stop water - continues to run even though tank is full
    What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
    Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
    http://www.plumbersurplus.com/pdf/1058802_2.pdf
    Kohler Toilet year old do not have flapper. It has stright pipe
    This is how it is meant to work!
    Short push of lever for small flush, push and hold lever for full flush.
    3helpful
    3answers
    Kohler one-piece has no flushing power
    Hi
    try to increase the amount of water for each flush .
    1helpful
    Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
    Top Kohler Home Experts
    john h
    ZJ Limited
    ZJ Limited
    Are you a Kohler Home Expert? Answer questions, earn points and help others
