Hotpoint Ultima WF860 Front Load Washer Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F-04 on my screen
Displaying f-04 on panel
Barry Coates
Level 3:
  • Hotpoint Master 3,463 Answers
  • Posted on May 15, 2009
Barry Coates
Hotpoint Master
Level 3:
Answers
3463
Questions
Helped
1405849
Points
12766
F04 means pressure/water level switch jammed on empty
Check pump and filter located at rear of washer behind removable panel.
Please rate my solution.
Thanks.
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
How can i open my Nokia c5-04
Warning: Do not enter any wrong unlock unlock codes on your Nokia C5-04 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C5-04 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C5-04.
3 - Compose #pw+CODE+1#.
4 - The Nokia C5-04 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C5-04 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C5-04
Each Nokia C5-04 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C5-04 mobile phone atwww.mobileunlocksolutions.com.
1helpful
F-04 on hotpoint ultima can you tell what this means please
"F04" on the display panel before the programme ends. Have you cleaned the filter out on the pump
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
After watching and recording, it displayed F 04 and did not eject
HELLO MARCELO!
This fault means that a new motor coupler and mode switch need to be fitted to your VCR.
This won't be a cheap job and it's up to you if you want it done. Personally, it will be a bit cheaper to get another VCR!
BEST OF LUCK! (:-)
PROBLEM WITH LANGUAGE
#Press the FUNCTION Key $Select the COPIER SETTINGS in Function Setting mode. (See page 36) %Touch the H key to advance to the 02/02 Display Screen of Copier Settings menu. &Touch the 09 KEY OPERATOR MODE key. (Enter the Key Operator’s ID Code and then press the OK key. )Follow the on screen instructions. *After setting, touch the OK key in Display Panel. +Press the RESET key, then exit the Function mode The screen to change the language is 01/05 option (04)
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
