SOURCE: compatible agp card for 8vm533m-rz motherboard
This board only has a 4X AGP slot so any AGP video card of 4X will do recommend 256MB or more if you can get it
SOURCE: sound problem
download your requisite drive from below site:-
http://www.giga-byte.com/Products/Motherboard/Default.aspx
SOURCE: gigabyte 8vm533m-rz sound problem
u should install your sound drivers without drivers no sound can be heared. it will be avaliable on your motherboard manufacturer cd if the sound is builtin.or if its separate sound card than u should have to download and install its drivers from its manufacturer website.if you dont have the cd of it.thanks
SOURCE: could you give me site
You can download the drivers from Gigabyte WEB support site. Please click on this link and select your model motherboard and then download the driver you require :-http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
if your computer is asking for a driver when you insert the windows 7 disc your motherboard maight not support windows 7 if its older than 5 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps
