I need to hard reset my blackberry 7105t
A reset of a BlackBerry smartphone does not delete any settings or data.There are two options for performing a reset: a hard reset and a soft reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry
smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Do a security wipe and reload the OS. Go to security options, general options, click the wheel and choose wipe the handheld. Make sure you have the handheld software installed on your pc (You can find it on the button above labeled BlackBerry FAQ's, follow the link to OS upgrade). If the Handheld software is installed connect to pc via usb cable, launch desktop manager, then launch application loader, and follow the prompts.
SOURCE: hour glass will not come off my 7105t blackberry
remove the battery and let the phone sit for one minute and put the battery back in.
your phone will do a full boot and it should be fine.
If not, you can download the blackberry desktop manager and the devise software for your phone and reinstall the software. then it will be good for sure.
unless it is really really broken, then a repair tech maybe.
