When pulled all way out it sticks and will not rewind
SOURCE: how do you get new fuel line into the gas tank of
FIrst off be sure you have the correct size line. Poulan uses several sizes of fuel line. If you got the wrong one, you won't get it to go in. The best way is to cut the tip of the fuel line at an angle. If you warm the fuel line before inserting it, it will go in easier. Once you get it forced in a little ways, you can reach in with a pair of needle nose pliers and pull on the fuel line while pushing it in from the outside. If you bought the line from a Poulan dealer, then instructions would be included along with the end being precut at a long angle to assist with installation.
SOURCE: need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
SOURCE: my Poulan chain saw has a sticking pull cord....r
Check the flywheel and flywheel key. It sounds like the timing is off.
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
SOURCE: I need a manual for my Poulan gas chain saw. It
Manufacturer's site here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
