Computers & Internet Logo
A
Anonymous Posted on Nov 13, 2013
APC SURT3000XL UPS shows red error light, does not charge
APC SURT3000XL UPS. When trying to power it up beeps and shows red X fault light, two battery lights, has no output. Tested the batteries in another identical unit, they are OK
Level 3:
  • APC Master 6,688 Answers
  • Posted on Jan 02, 2019
Cindy  Wells
APC Master
Level 3:
Answers
6688
Questions
0
Helped
3532491
Points
21745
APC lists the SURTA3000XL and SURTD3000XL on their regional web sites. In either case, the red X indicates an internal fault. If the unit is under warranty, contact APC for repair. Otherwise, replace the UPS. See page 15 (page 16 of the PDF) of the manual, available oon the product page: https://www.schneider-electric.com/en/product/SURTA3000XL_APC/apc-smart-ups-rt-3000va-120v/ . The current link to the manual is http://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=ASTE-6Z8LQA_R2_EN.pdf&p_Doc_Ref=APC_ASTE-6Z8LQA_EN .
Since the unit isn't charging, the charging circuit is either damaged or after the faulty wiring inside the unit. Unplug the UPS and do not try to use it. I wish that I had better news for you.
5 Related Answers
Anonymous
  • 262 Answers
  • Posted on Jun 13, 2008
SOURCE: Replace battey light blinking, beeping
sounds like battery Mite still be bad ? check and see again lala linda
Anonymous
  • 8 Answers
  • Posted on Sep 13, 2008
SOURCE: apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
upspro
  • 25 Answers
  • Posted on Jul 11, 2009
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Jesrey Paco-in
  • 91 Answers
  • Posted on Aug 14, 2009
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Shawn DuRee
  • 356 Answers
  • Posted on Apr 29, 2010
SOURCE: All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Blinking red and green lights
Check battery and charging voltages. APC says 90% of faults are a dead battery. My experience also
2answers
What can you advice me to do? i have a UPS SURTD5000XLI, indicating a red Led light, but when i remove it from the AC power source, the Red Led also remove & when i flog it again to the AC Source it...
Is red light on for overload or for battery?
If on overload, try reducing the load on the UPS. If red light on overload persists buy a new UPS (overload fault hard to repair).
Red light on battery - replace the batteries.
Red light on boost or buck, may mean that the nominal voltage of ups and the limits need to be changed/corrected.
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
2answers
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
1helpful
UPS SURTD5000XLIQ is being powered but indicating red Led fault , What may be the cause ?
it is cause by UPS internal fault, possibilities like faulty charging circuit, inverter, etc.. you can call APC and check if its still have warranty, APC will replace it right away :D
2helpful
2answers
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
I have a BX900R that suddenly the red light came on and the alarm sound was constant - not beeping and the unit did not supply any backup power. The most recent status on the monitor program showed about...
If the device was still under warranty, you should call APC support and ask to send it in for repairs or replacement. Just keep politely asking, and ask to talk to their superior whenever they say it isn't possible and eventually you will get an RMA ticket/number.
If the device is not under warranty, you might be able to convince APC to service the device for a fee.
When a UPS beeps and produce some sound and it is connected to power what can be problem and how can it be solved ?
SY8KRFSH (why is this number so bogus?)_ RARE
or means not sold in USA. or canada...
I can not look up UPS outside USA or N;America
and no country told
nor your towns , AC power voltage. ratings
2002 MADE, NEW.
symmetra 8kva n+1 (sy8krfsh)?
8000 WATTS, MEDIUM SIZED, COMMERCIAL GRADE NOT FOR HOME USE.
the manual covers this.
it shows all error codes possible and causes
simple to harder.
the beep is even normal
at loss of utility power. 100% normal
unless turned off by you. it is a feature
other beeps mean hardware errors, battery bad tops that list.
and lots more.
this old UPS has 4 LED status and LCD display to see errors
the manual covers the, im reading it now at APC. dot com.
read page 59
here
https://download.schneider-electric.com/files?p_File_Name=ASTE-6Z8L9J_R0_EN.pdf&p_Doc_Ref=SPD_ASTE-6Z8L9J_EN&p_enDocType=User+guide
see log view in LCD look there.
read the errors there.
the right far LED is marked FAULT if glows that means see logs
or run diagnostics from the LCD menu.
but find the right manual first.
or call APC on the phone
or call for service from them
or find a local UPS tech and ask for support.
answered all 4 ways.
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
