PAL VHS bought from England won't play in my (USA) Sanyo VCR
I have a Sanyo VCR Plus+/Model VHR-5423. I bought a VHS tape from England via eBay, and it won't work in my VCR. I live in the United States--in Texas. I understand this is because, as it says on the tape, it is PAL coded. When I try to play it the tv screen remains black and the sound is like cartoon characters. My VCR is hooked up to a Philips flat screen HDTV bought at Best Buy in Texas. Is there any way I can make this VHS tape play normally? Thanks so much in advance. --Chris
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Your end of tape sensor is not working. Notice the beginning and end of each tape is clear? That is to allow IR (infared light) which you cannot see with out special stuff, into the area near the left and right of the cassette. Usually they look like a tiny light bulb wit a left and right side. Radio SHack carrys IR detectors cheap.
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
The video standard in Japan is PAL while it is NTSC here in the USA. You should be able to locate a VCR than can play both. If you'd rather not purchase a new VCR, some locations that create DVDs from VHS tapes can usually also read PAL tapes.
Dan
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
YOu should have your our from your cam to the input of your vcr and the output of the vcr to the input of the tv... then simply set your vcr to the input channel that your cam is connected to ans it should show up on the tv, if it does not hit the tv/vcr button on the remote ... hit record and our done
Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions.
You are quite correct "Plays NTSC tapes to NTSC,
Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom.
Hope this be of some help to you. Good luck and kind regards.
