You can get everything off by following the instructions in the manual except the front bar holding on the cloth seat. If you look underneath you will see three white plastic rectangular tabs. Note that the holes are the same size as the plastic tabs, if you could turn the plastic tabs. They are all connected to each other by a 12” strip hidden inside the cloth. The trick is to go halfway between the center tab and one of the other tabs and put your finger between the plastic support structure and the 12” plastic strip. By gently pulling that out you can grasp the plastic strip. While holding that side out, go between the center tab and the other tab and do the same. With hands on both sides of center, you can easily rotate the center of the strip about 45° counterclockwise and the center tab will release. The other two tabs need to be rotated 90° then they will come out also. Wash and then reinstall. Hope this helps!
SOURCE: Assembling seat of chicco dj baby walker
Possibly the worst instructions I have ever seen! However, I got it in the end. Reference the manual and follow these instructions. The padded seat folds over the the rigid backrest (c) (don't do this yet!). Start by dropping the front 2 rings through the slots, then, put your finger through the ring underneath the walker and pull (quite hard) until it comes right through and folds over so it can't pull back out. The seam of the padded seat fits into the groove where the ring slots are. repeat this for the next 2 and it should work itself out from there. Hope that helps!
SOURCE: Chicco UFO baby walker seat damaged
go to your local retail store and find a baby walker just like the one that you have and explain your situation and ask for a copy of the manual. in the manuel, find and warrenty with the company and reapair/parts number and they will help you
SOURCE: where in scotland can i buy a new seat for a
For spare parts you'll need to either contact Chicco direct or pop into a local stockist of Chicco products who should be able to order the spare parts in for you. Make sure you know the model or at least have a picture of the item so they know which one you need.
Chicco U.K. Ltd
Prospect Close
M. Lowmoor Road
Industrial Estate
KIRKBY IN ASHFIELD (NOTTINGHAMSHIRE NG. 17 7 LF)
(0044) 1623-750870
(0044) 1623-723880 (fax)
[email protected]
SOURCE: Replacement console for chicco baby walker
Most likely! look through the items manual ,usually there would be anuber or web address! try those out!
SOURCE: replacement seat for dj seventy baby walker
DJ spares may be obtained from Stork Talk on 01159 306 700, I just ordered a seat and it cost £22.
