Question about Spectroniq PD-1100 DVD Player
Reads "wrong disc" when I insert any disc
Put dvd in and it says "wrong disc" for any disc I put in
    New Friend:
Wrong disc everytime i put a dvd in.
Posted on Jan 02, 2010
  • Anonymous Jan 02, 2010
    nope that did not work !!!!
    Champion:
  • 224 Answers
Tru cleaning your lens,(pysically) give it a blow ,or similar
Posted on May 04, 2009
5 Suggested Answers
6ya staff
SOURCE:
Komal Brar
  • 4 Answers
SOURCE: Dvd reads wrong disc
Since 4 days I've searched 99% of internet to fix 'Wrong Disk' solution for my DVDV822-05 Player, but I could not get any such solution. Some solutions for other players of the same company is to change region codes but I could not find these codes for this particular model. I got this player from some other country which I dont know. It's sayying 'Wrong Disk' to all disks either MP3, audio, VCD, DVD etc. It's my humble request to all e-guys and companies to find some solution for this model.
Posted on Jan 22, 2008
Anonymous
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
dennis bullard
  • 4090 Answers
SOURCE: I have a Samsung DVD-R155. When I insert a DVD,
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Posted on Aug 15, 2009
Anonymous
SOURCE: DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
Posted on Jan 01, 2010
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
Warfdale portable dvd player wont play dvd wrong discs
It may have a setting in the menu for DVD or CD but should on its own play either if designed for that.
Also if all discs give this reading it can be either a dirty or bad optical pickup in the unit.
May 20, 2012 | Televison & Video
The dvd player will not read the disks. There are A couple movies it will play but very selective on which ones it will read. We tried two brand new ones and it won't read those either. Any ideas? the...
When dvd player is selecting disc, the lens is weak. After sometime, it will not read any disc you insert.
If you change the lens it will stop the selection of disc.
Thanks.
Jul 23, 2010 | Televison & Video
Dvd won't play disc
hi. the actual lens assembly has become unstable and this is misaligned the lens. it is unable to line up correctly with the inserted disk so that it may recognize and read the data. when this occurs, the default reading will be WRONG DISK.
You with have to replace the entire lens assembly, which is one whole piece, to actually restore this unit to its original state.
Please rate and god less:)
May 13, 2009 | RCA Televison & Video
When I put certain dvd's it would say I should still insert a dvd.
that happens when u insert a disc of the wrong region,PAL disc in NTSC only player and vice versa or if the disc is damaged and cant be read..hope it helps!
Nov 26, 2008 | FEC RKMV5 Custom Rackmount Kit for JVC...
Not recognizing any DVD inserted on my DVD player
dust in lens mean dvd does read! clean the lens with disc cleaner! some problem comes again mean you want to change the lens!
Jul 01, 2008 | JVC XV-S300 DVD Player
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Spectroniq PD-1100 DVD Player Logo
1,141 people viewed this question
Top Spectroniq Televison & Video Experts
Ekse
Charles Tidwell
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
