Microwave Ovens Logo
Gloria G Mehlbrech Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My microwave oven has are rust spots;can I paint over them?
I over cleaned my microwave oven & now there are rust spots by the turntable; can the rust be painted with enamel paint? Would painting inside of microwave oven be dangerous?
  • Gloria G Mehlbrech May 04, 2009
    Thanks for the info; now I feel better as manufacturer stated it was a loss cause and needed to buy a new microwave oven....thanks again
  • Anonymous Jun 20, 2013
    I am not talking about rust. I am talking about something that oozes out of the door near the hinge. It is a black power-like dust that I suspect may be insolation.
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on May 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
765723
Points
4966
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
1 Related Answer
Anonymous
  • 30 Answers
SOURCE: Can I paint rust spots w/enamel paint? Dangerous to use?
You will need to buy a appliance high heat paint. the spray can works the best.
How to clean rust from microwave turntable track and repaint
Search for Microwave Spray Paint on eBay or Amazon.com.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
4helpful
The microwave oven coating is peeling and exposing rust spots. what can I do to fix this? Do I need a professional repair person?
No this is something you can repair yourself. Take sandpaper and gently rub rust spots until smooth. Then you need to get ceramic touch-up paint and repaint rust spots.
2helpful
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
Hello i have a problem with my microwave I used an abrasive cleaner on bottom of microwave under the turntable it has now started to rust at this stage surface rust only is it repairable
Yes you can, it is a painted surface correct? If so buy some rust inhibitor spay or primer and spary the bottom and then paint. Make sure you tape off any vents on the bottom before you do anything
8helpful
Rust under turntable of microwave can i paint it?
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
2helpful
1helpful
3helpful
Enamel under the glass turntable has flaked off
This is due to spills, accumulated moisture from steam / condensation, or both.
It can also be worse if your internal cooling fan is not running, or if the vents or filters are blocked or clogged.
Since the the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and then dried thoroughly.
Let it dry overnight with the microwave door open.
Once that's done, you should occasionally look for accumulated moisture on the floor of the oven and keep it dry.
The model number tag should tell you where it was made.
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
1helpful
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
