Verbatim External, USB 2.0, 750GB Capacity, Silver . 750 GB Hard Drive Logo
A
Anonymous Posted on Nov 11, 2013
I have a verbatim external hard drive , how do I store it for future use
5 Related Answers
chris johnson
  • 12 Answers
  • Posted on May 01, 2009
SOURCE: Undetectable External hard drive
i am unsure about this but its worth trying
go to start control panel administrative tools services and look for plug and play and make sure it is set to auto at start up and enabled it so it is started this lets your computer recognize new hardware on your computer which should let see it in your my computer screen
i hope this as help if not well i tryed
Anonymous
  • 13 Answers
  • Posted on Aug 08, 2009
SOURCE: 1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
YourZEN
YourZEN
  • 820 Answers
  • Posted on Sep 24, 2009
SOURCE: WinXP does not recognize USB device for Verbatim
Troubleshooting your USB hard drive in Windows see:
http://www.verbatim.com/support/support-article.cfm?support_id=7B8B6B2C-1422-1392-A8B4CF52416BBF75&supportType=Article
  • First check:
Link to determine the hard drive getting enough power:
http://www.verbatim.com/support/support-article.cfm?support_id=7B4B78B1-1422-1392-A837F379D15C6F2E&supportType=Article
  • Next check the hardware in My Computer > Device Manager if there are "yellow marks" for devices that require driver software to be installed.
When devices e.g. printer is connected before you installed the needed software, it can happen that the USB port is no longer recognized.
Then remove the device that shows having problems in the hardware manager.
Next install the software.
Connect afterwards or at the time the computer asks to do so.
Link to your external hard drive USB 500GB on the internet:
http://www.verbatim.com/products/detail.cfm?product_id=A2EDE0FA-1143-3415-5F5A5A7E80921FE8&cat_id=A2EEE0D6-1143-3415-5FC347F5645B6AE1
Anonymous
  • 6831 Answers
  • Posted on Sep 29, 2009
SOURCE: I have an external hard drive back up, Verbatim,
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Daniel DiGriz
  • 4 Answers
  • Posted on Feb 23, 2010
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
I have a verbatim 1.5 TB external hard drive,how can I delete some of the stored files,verbatim answered by telling to delete everything!
You should be able to open windows explorer, navigate to the external hard drive, click on it and see the files which are there. Then you can pick the ones you want to delete and delete them.
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
External hard disk
You should not need a disk to get an external hard disk initialized. Did you try to plug it into your PC and see if it detects it?
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products:
CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers
For online support click here:
http://www.verbatim.com/contact-login.cfm
or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time.
Verbatim Acquires SmartDisk External Hard
Disk Drive Business
Verbatim Acquires SmartDisk External Hard Disk Drive
TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business.
The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
1helpful
2answers
Hi! I stored files, docs, and pics, on my Verbatim Ext. Hard Drive USB 2.0 awhile back. I now want to update it. When I go to "shortcut to Verbatim" I get a Nero BackItUP Archive File page. When I...
Connect the external drive.
Open 'My Computer'.
One of the icons should be associated with the external drive.
Double-click the icon to "open" the external drive, to show the files/folders on the drive.
2answers
I dropped 500gb verbatim external drive. It wants me to format the drive. How can i get the data back before i format it? Please help Thank you
Because the first few records stored on the disk-drive have been corrupted (or are physically unreadable), you get the "please format" message. Hopefully, the other 99.9 percent of the data-blocks stored on the disk-drive are OK.
Search online for 'data recovery' software -- it reads through the disk-drive, block-by-block, trying to merge blocks of data back into files that can be copied onto your 'C:' drive.
Paul
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
