It does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
SOURCE: how do i remove cover on food chopper? kenmore 665
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
SOURCE: I have a kenmore elite and none of my dishes are coming out clean
Well, if the motor is moving, try adding a half gallon of /hot/ water before you start the cycle (just pour a saucepan full directly into the dishwasher). If that sounds like it is doing a lot more "blasting" than it was before- you probably need a new water inlet valve, or perhaps to take your water inlet valve off and try to clean out the screen. Problem being, you arent getting enough water into the washer before it starts washing.
It is located at the front of the machine behind the panel under the door.. but as a check, make sure that the valve under the sink that sends water to the dishwasher is all the way open, as this can cause the same problem.
If you do decide to remove the valve, be sure to cut the power at the breaker, or unplug the dishwasher, and turn off the water valve under the sink.
SOURCE: kenmore dishwasher not cleaning properly
Our Kenmore was not cleaning the upper dishes properly also. Obviously the water pressure delivered by the pump was restricted. Under the lower spinner and a larger plastic plate held on with 4 Torx screws and a smaller cover (2 more screws) over a small grinder cutter arm connected to the pump running around a circular metal perforated disk. This disk was clogged with the plastic from the dishwasher tabs - DON'T USE THEM!
Sadly the clog had also damaged plastic end of the pump that engaged with this spinning "cutter arm" so I had to modify the arm to make it fit again.
Once we stopped using the Tabs, all our problems disappeared.
