Kenmore 62622 Microwave Oven Logo
C
Cath Little Posted on Nov 12, 2013
Kenmore 85413 Keypad does not work
Kenmore microwave 721 keypad buttons does not work.
The key pad or the system Bord is faulty. You have replace the keypad unit first.
If you wish to get any more detailsthen check the bellow added link.
www.electro-medical.blogspot.com
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
Buttons not working on keypad of microwave
The keypad control board is defective and must be replaced.
I have a Kenmor Elite microwave oven, model 721.66460400. The timer no longer work properly, i.e., I cannot set the cooking on button. Where would I find someone to provide parts and perfom work to get...
It sounds like a failed membrane keypad.
On some models, you have to buy a separate keypad.
I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
In other cases, you can replace the whole control panel frame assembly, which comes with a ney keypad already on it. This runs more, but it's much simpler.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
You can find helpful exploded views and order parts from the Sears Parts Direct Web site.
That model number (721.66460400) is not showing up in my search. Please check it again.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
11helpful
Kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
take yours off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
take yours off as in the video at our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
I am trying to locate an online downloadable installation guide for the Kenmore microwave model no. 85413 for free. Can you be of assistance to me? Christine
Just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
1helpful
Keypad only works
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
