Replace the sd car tap on change preferences than tap switch map than tap india if the map is not working you can download it from www.thepiratepay.org
SOURCE: my tomtom go510 will not turn on
I did get it going again ,i hit the reset buttton and it started working again thank you for getting back with me rtrailbuster''
SOURCE: SDHC card in TOMTOM 510
sorry but i dont think tomtom 510 supports SDHC cards you will need a non SDHC card try
https://www.memorybits.co.uk/
SOURCE: tomtom go510 does not power
TT 510/710/910 have similar problems with having it on while not used for a long time. The battery is not charged because of a low voltage on it. The easiest is to turn the device apart, and short-circuit it with the power adapter. After around 15-30mins it should get to a higher level, and then start charging normally. The ultimate solution is not letting it discharge to 0... :(
SOURCE: i want to know if my tomtom go510 can be disable
dont worry it will explode when they try to update it! just like the two I had!
SOURCE: We have a tomtom GO510 and we called and the
You need to go to the TomTom web site and register, then you can download the necessary software install that and THEN & only then connect up your GPS, with the USB cable, & turn on. Then you will be able to update it. Via the internet.
what did u mean by replace the sd card? did you want me to remove the sd card? also I checked the website thepiratepay.org I didnt find anything relating to the maps for india over there. I wanted to confirm that there is no maps provided by TomTom available. I will have to find an alternative provider such as mapmyindia.com or satguide.in and replace the firmware which is currently on my system with theirs. Please advise.
Thx
Ravi
