Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
its either you have to make sure there is spark, then check your fuel filter in the tank or on the inlet fuel line comin g from the fuel tank. there could b some condensation or dirt in the tank . U could also check the diaphram in the carburetor.
First of all make sure the air filter is clean. Next I would dunp the gas out of the saw and put fresh gasoline oil mixture back in the fuel tank. Maybe a little condensation water got in the fuel you had in the tank.
well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
verify condition by spraying some starter fuel in it.it should start and die if its a fuel problem.
if it still does nothing start checking any and all fuses.if all the fuses are good take out a spark plug and verify no spark.
if no spark check the ignition module.
it might be able to have it checked at autozone for free.but you will have to remove it.
The stabilizer is a bad thing for some carbs. It has a chemical in it that can eat away seals and gaskets inside your carb. Grab a gasket set for it, replace those, make sure to spray the carb out, then put it all back together adn you should be ok.
