I've replaced the potentiometer unit with a new one but no joy
Your control board is probably going out. Will need to replace eventually.
Thank you for taking the time to post, however I have fixed the problem, upon taking the cover off & having another look I noticed the high speed gears had become miss aligned (the gear on the vertical shaft had worked it's way upward) thereby causing the tachometer sensor to give false readings. I pushed the gear back down & it works fine.
