SanDisk Sansa e260 MP3 Player Logo
Posted on Oct 06, 2007
I DONT KNOW HOW TO REFRESH MY SANSA MP3
I DONT KNOW HOW TO REFRESH IT I TRY TO DO THE SAME THING IT SAYS IN THE SYSTEM BUT IT DONT WORK....AND I CANT EVEN HEAR SONGS AND SOPOESLY I DONT HAVE NO SONGS SO HOW CAN I REFRESH MY SANSA
  • Anonymous Feb 09, 2008
    My Sansa View Mp3 Player keeps Freezing and then turns off. What do I do?
A
Anonymous
Hold down the on button on the bottom left hand side, keep holding it till the sansa turns itself off.  After its turned off switch it back on, ive had the same message up many times
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
1helpful
Sansa e250 blue screen
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
2answers
What does "Refreshing Database" mean?
You will need to upgrade or reinstall the firmware on your MP3 player. You may download the firmware on http://www.sandisk.com/Retail/Default.aspx?CatID=1376. For the manual installation of the firmware upgrade, you may go to this site: http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
2answers
Sreen froze on refreshing data
direct us to the drivers needed to install unit on pc thanks sansa e260
Sansa e270 refresh database
What I would recommend you to do is format the device and reinstall the firmware..the link to install the firmware is below..
Hope this helps
If you need further assistance please contact me..
Please rate accordingly
Thank You
Computerrep
Go under settings and change USB Mode to other choice. Then format. After formatting change back to original setting. I had same prob. Tech support told me to do this and it worked. Have had no problem since.
2answers
Sansa e250 problem
If You Have Bitlord You can Download The Sansa Converter. To do that go to search and Type Sansa Media Converter 1.3
Black screen
i dont know what the problem might be but u should try calling sandisk they should know what to do. hope it helps
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
