Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
Posted on Oct 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch diswasher It takes almost 4 hours to run through a full cycle. It seems to stay in the rinse/dry for too long.
bwepp
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 08, 2008
bwepp
Contributor
Level 1:
Answers
Questions
0
Helped
289
Points
Not sure but it could be that the washer thiks it needs water (i.e. the water us syphoning out as it is coming into the dw. I hav a fairly new Sears Kenmore and the problem was that the drain hose not eleveated enough. My fw is on main floor and drain hose goes down thru the floor into the basement. What was happening was that when the 1st drain occurred "gravity" caused the new water to continue to syphon and it would stay in a cycle for a long time. I corrected by re-running my drain hose to the the drin below the kitchen sink. That drain is elevated above the floor enough so gravity does not take over. Hope this helps.
Anonymous
Level 2:
  • Expert 209 Answers
  • Posted on Oct 07, 2007
Anonymous
Expert
Level 2:
Answers
209
Questions
Helped
119506
Points
570
Check heater element for open circuit, if the dishwasher fills and empties and wooshes the water round, there is little else to go wrong
2answers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 • Dishwashers
Bosch Diswasher won't pump water out after cycle
it needs a new drain pump for around $65 dollars. the install will take close to $90-$120.
2helpful
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 • Dishwashers
2answers
Dishwahser rinse cycle running for hours
It sounds like a thermal stop. The water in the rinse wants to get up to a certain temp to satisfy the thermistor but doesn't reach it so it will stay there. If you have an amp probe you can put it on to see if the heater is coming on. This could be your problem.
Sgt 48
3answers
Do you have high temp rinse or sanitize selected? This will pause the timer during the final rinse cycle to heat the water. The sensor might be bad. Try the quick cycle, I don't think this heats the water.
2answers
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
Dishwasher runs but does not clean
Try using a cycle that doesn't heat the water. (Quick cycle?) Using high heat rinse or sanitize will stop the timer while it heats the water. The sensor may be bad.
1helpful
Bosch SHU430UC/06
ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
