sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
1. Remove the unit from the base.
2. Twist the top clockwise to separate the two halves.
3. Grasp the filter tab to lift it up.
4. Empty filter, replace, reassemble.
your motor in the vacum is getting hot.Thats why it shuts off.Its fitted with a shut off switch to stop you doing any damage to it.1 The reason for getting to hot is that you are filling the cannister to full.Try emptying it half.good luck.
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
My filter fell apart on my dirt devil featherlite CE6000. I have only used this 4 times.Where can I find one? I have looked at several stores.
Sincerly,
Pennie Silverman
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
