Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red led light flashes 6 times and tv won't turn on
Panasonic pt-53x54 won't turn on red led light flashing
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on May 03, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407290
Points
3279
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
1helpful
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
1helpful
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
1helpful
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
1helpful
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
1helpful
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
1helpful
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
