Panasonic TH-50PZ77U 50" Class Plasma HDTV Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm looking for a sound regulator for an HDTV with hdmi connection
Ginko
Level 3:
  • Panasonic Master 19,396 Answers
  • Posted on May 03, 2009
Ginko
Panasonic Master
Level 3:
Answers
19396
Questions
25
Helped
8074128
Points
55462
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
1helpful
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
2answers
I hooked up my HDTV with a HDMI cable but when I used the Audio L/R cables, I can't get any sound. I can get sound if I hook up the TV with regular cables but then I don't get the HDTV picture. Any...
You may have to go into the TV setup menu and change a setting for Sound (or Audio) that tells the TV which input to use (HDMI or component) for sound. Usually the HDMI connection will work automatically but if you connect cables to Audio L/R that may override the HDMI sound input.
2helpful
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
