Whirlpool Duet GHW9150P Front Load Washer Logo
Steve Parker Posted on Oct 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear bearing noise when drum rotates
Washer makes a loud grinding noise from rear of drum. The faster drum rotates the louder the noise. Can problem be repaired reasonably if it is rear bearing.
  • Anonymous Mar 23, 2014
    Bearing noise from drum
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Oct 06, 2007
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734285
Points
22413
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Anonymous
Level 2:
  • Expert 290 Answers
Anonymous
Expert
Level 2:
Answers
290
Questions
Helped
313612
Points
924
Check the warranty in your owners manual. Your parts should still be in warranty (basket and tub). You will have to pay labor, about $200. Turn it by hand and listen carefully to be sure it isn't something that has gotten between tub and basket.
  • Anonymous Oct 08, 2007
    Just wanted to follow up on your washer problem and see what you found wrong.
    Thanks/Mike
Has there been any problems with the bearings when the machine is in the spin cycle. loud grinding noise
Bangs, thumps, grinding? If your washer is making a loud noise you can be sure it has something to do with a bearing. But which one? There are two common bearings inside washing machines: the rear drum bearing or a tub bearing.
I found this info below. Check it out for more help with your issue.
https://www.electrafixbc.ca/appliances/washer.html
Loud rear whine, not brakes new ones fitted
Was noise there prior to brake replacement? If so, possible wheel bearing noise. Noise should get louder the faster the wheel rotates with a bearing problem.
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
3answers
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
1helpful
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
1helpful
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
1helpful
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
2helpful
Washer problems
Hi there!
The problem is probably the main drum bearing at the back.
Isolate power and water supplies.
The top will have to come off,(screws along top edge at back), then the motor mount slackened to remove the belt. Then try rotating the drum by hand, If the noise is still there, check for any items lodged between metal drum, and the outer plastic wash tub. If everything is clear, The noise will be from the rear bearing, which needs to be replaced.
I can assist you further with this.
1helpful
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
