Contributor
- Posted on May 07, 2009
Re: Carrier Infinity System Thermostat...The actual temp...
Call your local company and check the warranty status on the Infinity UI it should still be under warranty and get a replacement otherwise it could run you a couple hundred dollars
Hi tomdee,
If the A/C is functioning properly, why is the temperature a constant 79 degrees? Is this where you want it and are manually keeping it there?
Are you saying the thermostat no longer control the system?
Charlie
